REALLY annoying problem right now, especially with a deadline looming!
I’m trying to render an irrad map on another computer via backburner. Everything seems to go fine, computer renders without error and saves a irrad map file. However that file is then unreadable, it’s a normal size but can’t be loaded in VRay or via the IR map viewer. I get an error saying “[V-Ray] Could not load irradiance map” (very descriptive, thank you VRay for the details… lol…)
Any ideas? I’m stumped and at the moment rendering IR maps on my station to see if it helps. Needless to say, not the best workflow…
Update: rendering the IR map on my computer w/o using backburner resulted in a flawless IR map. So there is something wonky when submitting an IR map to backburner to render on a single networked comp.
Hmm… Could backburner be killing max after the render before it has a chance to write the IR map to disk?
Christopher, which 3dsmax/backburner/vray versions do you have? Also, there is an option for V-Ray to save the irradiance map at the end of each frame, instead of the end of the rendering, make sure this is on.
