Vray Beta 5 IPR Unhandled Excpetion error
Im running into Unhandled Exception errors when working with Forest Pack while rendering with IPR. Maybe Im just taxing the system too much. When using IPR, just removing Forest Pack items from the render will throw the error. I can imagine if ADDING Forest Pack items but removing them for lower memory consumption? weird. One nice thing is that when getting the error, it doesn’t crash Max. It will allow me to at least save the scene but I do have to restart Max to use GPU again.
Edit: I also cannot advance the time-slider at all or it throws the same exception.
You must have Forest Pack that is explicitly compatible with V-Ray 5.
Yes, Ive already updated Forest Pack.
Where did you get the build from? The latest FP version I’m seeing is compatible with V-Ray 5 Beta and not the official one.
