Somewhere in recent update time parameters in vray bitmap got broken. Start frame does nothing and when we open old scenes there is weird number 192192 where 1001 used to be. Can someone confirm this bug?
Hi, can you provide a scene containing these issues. It would be easier to debug. Thanks.
I think I’m reproducing your issue (in 3ds Max only Start Frame = 0 or 1 seem to work properly). ̶I̶n̶ ̶S̶t̶a̶n̶d̶a̶l̶o̶n̶e̶,̶ ̶e̶v̶e̶r̶y̶t̶h̶i̶n̶g̶ ̶w̶o̶r̶k̶s̶ ̶f̶i̶n̶e̶.̶ ̶M̶i̶n̶d̶ ̶i̶f̶ ̶y̶o̶u̶ ̶t̶r̶y̶ ̶S̶T̶D̶ ̶(̶V̶-̶R̶a̶y̶ ̶>̶ ̶.̶v̶r̶s̶c̶e̶n̶e̶ ̶e̶x̶p̶o̶r̶t̶e̶r̶ ̶>̶ ̶e̶x̶p̶o̶r̶t̶ ̶a̶n̶d̶ ̶r̶e̶n̶d̶e̶r̶)̶ ̶t̶o̶ ̶c̶o̶n̶f̶i̶r̶m̶?̶
edit: nevermind.
Unsure about the odd number. Indeed, send a scene.
File uploaded. Is looks even more weird now. Frame hold doesnt work, it needs to be set to loop also it works only in ipr but not in production render
and the odd number works only when fps is set to 25.
Yeah, okay. Something is very messed up - I can’t figure out why it’s not working; it seems like some kind of value-scaling issue or something. Will log it for dev investigation.
EDIT: Logged as (VMAX-15915).
Good news.
The devs found the cause of the issue: it seems there seems to be a change in 3ds Max 2027 where we show TICKS instead of FRAMES. 1 second = 4800 ticks. For 25 fps, 4800 / 25 = 192 ticks per frame (frame 1 = 192, frame 2 = 384, etc). Old scenes are converted, so in your case, frame 1001 x 192 = 192 192.
We’ll fix this.
Hi, is this already fixed?
In the internal builds - yes. Will most likely get picked for the next official update.
if its in nightlies i can pick it up right now
The fix is not yet in the experimental builds. I’ll let you know when a build is available.
