Vray blend material with vray override materials?
I have a Vray blend material with 2 vray override materials, but I don’t see anything in the material preview. Will it render? Maybe I need to use a max blend material for this one?
This has been corrected for newer builds, but for now you can try to put the blend inside an override material (or use regular blend).
