Vray Camera Target Undo
I have a simple pan of a room, autokeyed from frames 1 to 100. I was working at frame 50 when I unchecked target, and then the position of the camera reset to the first frame losing the animation sequence. I went to undo this but it doesn’t reset my cameras position to the way it was.
lucky you!!!
:lol:
Will try to replicate this myself soon.
Lele
On a side note, about the vraycam: if i keep switching between targeted and free, the target object is NEW every time. That, or it changes wirecolour every time.
So that may be a reason why it lost some animation.
Might be the camera, while not changing name or colour, does change as actual scene node.
Would need Vlado for this, though.
Lele
