Vray Clipper
Hi There,
I’ve modelled an appartment building with the interiors.
My cliend would need some renderd plans from the interiors.
So I decided to work with the vray clipper as I’ve used this before.
For this I’m using 2 clippers at the same time to get the desired result: a wall cut off at 90cm height, and the interior objects at about 180cm
So I’ve got 2 clippers which I’ve carefully placed (based on a mesh bounding box)
- A: only including the architecture solid
- B: only excluding the architecture solid
This is giving me this strange results: (have a look at the attachments).
I’ve indicated the issues on one of the screenshots.
try turning off Embree
Hi Brendan,
Thank you for your reply, I’ve read about the embree function and already tried that, without any luck…
Might also depend on if you’re rendering progressive or bucket, and also cpu vs gpu? I’ve seen those similar radial artifacts and I thought they cleared up when turning off embree.. The type of geometry being clipped can also cause issue if it isn’t a geometry with thickness.
Hi, looks like it’s going better now, I’ve removed the clipping mesh and replaced it with a clipping plane…
Oh sorry I missed that you were using clipping geometry! You can also include/exclude with the clipping plane so maybe you’ll still be able to clip how you were clipping with geometry.
np, but I was doing that as I said in the A/B:
might be something else…
anyway, looks like I’ll go with the planar slicer.
thanks for the help
maybe exclude the grass from the clipper?
would be great, but how do I do that if I already chose 1 include object (the architecture main model)
Can you include obj a, and exclude obj b?
Otherwise I’ll have to use include and then update this each time when I make a change, would be a lot of work.
Oh if you’re already using include on other geo than the grass shouldn’t be affected. Hmm.
Are all the trees part of one single Forest object ? If so - can you try to split them to a few separate objects ? If it is one single object all around the building and the tree models have single sided leafs it might throw off some of the internals of the Clipper.
Or if you could send the scene to our support - we can check what is going on exactly.
Yavor
I had some issues with Clipper solved by increasing transparency levels in the render settings.
Hi Ashley, thank you for your reply, I’ll try that.
@Yavor, I’ll have a look at that, and send the scene file to the support, I had to send it anyway cause I also have some trouble with the auto exposure option.
So did raising the transparency levels, solve your issue?
Hi Ashley,
Looks like it got improved, but not all the way.
Also what number would you use for the max transp. levels? I rendered with 300 now.
The grass remains the same, some regions are rendered fine, other are not properly filled.
I’ll be sending the file to the support so they can have a look at it.
Thanks for following up.
Any follow up on this? We’re having the same problems haha :slight_smile:
Thanks for the answer will have to find another solution then too.
If you can send the scene to support we might be able to help narrowing down the problem.
Thanks Yavor, we’ve managed to solve the issues at hand. No bugs here :slight_smile:
