VRay Cloud problem
I have problem with VRay Cloud. Clod is really easy and working great, but the textures in scene looks different. I have 4.02 and Cloud probably works on 4.03, dont know if this cause the differences or its something else.
Do you get any messages in the scene analysis report when you export for the cloud ?
Yavor
No, no messages.
Then can you send the scene to our support - they can investigate what causes those differences.
Include a link for reference to this thread in the same email.
I just replied to the ticket you have created about this render difference, but will post the resolution here as well.
The main difference on the road mapping is caused by the Noise (Fractal) map which is converted internally to our Noise plugins to be rendered in Standalone or Cloud. This conversion can make the pattern look different like in this case so my advice is to use our VraypluginNodetex (noise) or to bake the result of the Noise map.
Second thing is the small difference in the bump, more specifically the V-Ray Normal map with strong bump amount set. I have logged in our system this to be reviewed by our developers.
So that’s it! I had the same issue with the noise map. Thanks for the explanation.
