vray color corrections for VP-IPR in 3dsmax window
how do i get the vray color corrections in a 3dsmax window next to the viewport IPR ?.. like in your promo video of update2
thanks for help
i think i got it now…it is not in the 3dsmax window, it only looks like. but where is the VFB window? covered behind the CC window?
cause when i close the VFB the CC window is also away.
For the video, the VFB is moved away to a second screen, I believe.
Thomes, If you clic the “globals…” button in the color correction panel you can untick “Dock Color Corection” and then have a floating window separated from the VFB that you can place on another screen. Is it what you wanted to do ?
You can also right-click on the color corrections button in the lower VFB toolbar (instead of the usual left-click) - the right-click will toggle the floating/docked version.
i knew that, but as i said, if i closed the VFB window the cc window also closed…so no possibility to separate it completely from VFB
right-click was new to me thanks vlado
