A simple question:
Is Vray for sketchup pro 6 compatible with Windows Vista 64 bit?
Grazie! Ciao!
A simple question:
Grazie! Ciao!
Re: Vray compatibility with Vista 64
Yep, it should be no problem. Vista’s install is tricky, so make sure that you run everything as an admin and everything has the right permissions.
ok! Thank you.
Ciao!
HELLO GUYS AM HAVING PROBLEM WITH MY V-RAY I HAVE WINDOWS VISTA AND THE I CAN’T INSTALL IT WITH MAX9
THANK YOU
We need more info. Describe what happens, when does it happend and what error messages if any do you get?
And ideally you should make a new thread if it’s not related to the original post. And please no Caps Lock.
