Vray Compatibility
Hello, compatibility of other vray tools is planned?
Vray fur, vray clipper, vray plane, some maps as softbox, and vray material as 2side, carpaint with flakes …
We do plan to support more V-Ray features, yes, but can’t give you a time frame on any particular one.
However, this also depends on how much adding them affects performance (even when the feature is not used).
Some features like V-Ray Fur and V-Ray Clipper’s include/exclude lists might have terrible performance without further hardware support.
So it’s possible they will be disabled by default if/when we have them.
Can you list the features in order of importance for you ?
Greetings,
Vladimir Nedev
Maybe adding the features in the form of plugins? where you can turn off the tools we don’t use?
I can’t go into details, but you can’t plugin GPU code as easy as you can CPU code.
Greetings,
Vladimir Nedev
The build that we just released (version 1.3.0 ) includes support for the 2-sided material.
There are some restrictions however.
Most notably, the translucency texture can be only a bitmap texture with simple UV mapping (Offset/Tiling/Tile options from 3ds Max are ok, but rotation is ignored).
When “Multiply by front diffuse” is enabled, the diffuse texture has the same restrictions.
Greetings,
Vladimir Nedev
