Vray Config File...is any such thing?
we have installed 3dsmax on some PCs, we have not registed it as these are going to be used as render nodes - we have also installed vray and rt on these too for network rendering.
Now because we cannot actualy run/open these copys of Max we also cannot open the Vray render settings to input all the VraySpawner server information of the studios other computers.
does anyone know a way around this?
Hope that makes sense?
cheers!
I thought the spawner was a standalone .exe in the max directory?
I’m pretty sure i’ve used DR on our farm and didnt need to start max up.
well…the spawner works fine, the problem is this…
I submit a render though backburner via my main work computer (with fully working 3dsmax) - Within this file I have turned on Vrays distrbuted rendering. When the file starts rendering on the render node pc it cannot find the Vray spawners on the other computers because that information has not been imputted into the vray settings on that computer because Im unable to run max and imput the settings.
Too simplify (I think)
GoTO - vray render settup/settings/Distributed rendering.
this information regarding IPs/names is computer dependnent, not scene dependent.. what I need is a way to copy that information to the renderNode computers without opening 3DSMax?
Search for a file called vray_dr.cfg. It’s location can vary depending on how your workstation is setup. Usually it will be in a path like this:
C:\Documents and Settings\Administrator\Local Settings\Application Data\Autodesk\3dsmax\9 - 32bit\enu\plugcfg
or
C:\Program Files\Autodesk\3ds Max 2009\plugcfg
Etc…
Sometimes the file is missing so you need to add it. You can copy it from your workstation and add nodes to the list if needed. Add a 1 to make a node active and a zero for inactive. Sometimes you have to experiment with the location to get it to work.
Yep, what arobbert wrote is correct; we will also be adding an option to transfer the render slaves list together with the scene for just these occasions.
i cannot find this file anywhere on mmy computer..
hints ?
You must change the V-Ray DR settings for this file to be created (e.g. add some render servers).
thanks i found it
I have DR enabled in a scene, I put the vray_dr.cfg file on the node BB server in both locations (program files/max/ etc, and local settings/etc.), add servers to the list (and even in the DR dialog I tell it to save list in scene), but when I submit the job to the BB server that I set up, it only renders with that one machine.
If I do DR on my workstation, it uses all the machines fine, but when I submit to BB server, it only shows buckets for the single BB machine.
Edit: Wanted to add my specs. Vray 1.5 SP5 in Max Design 2011 64 bit on xp pro 64 bit. All machines can see each other and I can do regular BB rendering (even DR rendering from my workstation), just the host node that has the vray_dr.cfg file won’t pick up the other DR nodes. Even after restarting DR on the nodes.
Edit Edit: Ok, I turned on BB server on my workstation with DR checked in the file and it only shows my machine rendering in DR mode (shows name in the buckets). I even turned off spawners on the nodes, then turned them on, before I activated the BB job. It does render fine when I have Max open. But DR doesn’t work through BB at all, even for my workstation. Any idea what that could be caused by?
Any info?
*bump* Anyone else have this problem?
There seems to be some problem there and I’m looking into it now.
Thanks, Vlado! This would help us out a lot if we can get this working properly. Looking forward to it!
Any word on a workaround, bugs, etc.?
The vray_dr.cfg file should work; just make sure the “Save hosts with scene” option is disabled when you save the scene (there seem to be some issues with it in SP5).
Thanks for the update Vlado! Will check and report back.
Trying to get a DR job running through backburner using Vray 1.50.SP5
Could you please clarify how this should be done?
So far, I have copied the file ‘vary_dr.cfg’ from C:\Documents and Settings\my.name\Local Settings\Application Data\Autodesk\3dsmax\2009 - 64bit\enu\plugcfg to one of our render slaves, NODE_01 to C:\Documents and Settings\administrator.DOMAIN\Local Settings\Application Data\Autodesk\3dsmax\2009 - 64bit\enu\plugcfg.
The file looks like this:-
node_01 1
node_02 1
node_03 1
node_04 1
node_05 1
node_06 1
node_07 1
node_08 1
restart_slaves 1
list_in_scene 0
Is this correct?
I then send the DR job to NODE_01 through backburner.
Yep, that should work if you run the backburner server with the administrator.DOMAIN user.
