VRay: Could not load the Bifrost module!
I just gave the 3.6 stable 27650 build a spin in Maya 2017 Update 4. I see this in my render log:
>>> Error: line 1: VRay: Could not load the Bifrost module! You will not be able to render Bifrost as isosurface or metaball. The error message is: dlopen failed: //FILESERVER/pipeline/bin/vray/builds/170831_vray_v3.60.01-stable-b27650-maya2017_linux64/maya_vray/bin/libvraybifrost.so: undefined symbol: _ZN12VRayBoost1616system16generic_categoryEv
Do you know what could be causing this issue?
on what OS do you get this error (judging from the log it might be Linux)? Are you running V-Ray from a zip install or the regular installation?
“Error: line 1: VRay: Could not load the Bifrost module! You will not be able to render Bifrost as isosurface or metaball” You should be getting this error only on OSX systems.
Yes, Linux (CentOS 7). It’s a zip install of V-Ray.
It looks like this is a known issue. I’ll bump it’s priority and we let you know when there is some new information about this.
Thank you for your feedback.
Ok, thanks Ivan.
Just checking back in… do you think this will get fixed for V-Ray 3.6?
which V-Ray version are you using 3.60.xx?
Hi, we’re on 3.60.04 official release for Maya 2018.3.
