I cant use VRay without Sketchup given bug splat error. Please help. Could it be an licensing issue? Please help. Below part of the error message:
Translated Report (Full Report Below)
Process: SketchUp [3035]
Path: /Applications/SketchUp 2023/SketchUp.app/Contents/MacOS/SketchUp
Identifier: com.sketchup.SketchUp.2023
Version: 23.1 (23.1.341)
Code Type: ARM-64 (Native)
Parent Process: launchd [1]
User ID: 501
Date/Time: 2024-01-05 16:58:36.1301 -0300
OS Version: macOS 14.2.1 (23C71)
Report Version: 12
Anonymous UUID: EDFFA1BD-24DD-F922-5B04-A98A89E769A7
Time Awake Since Boot: 4700 seconds
System Integrity Protection: enabled
Crashed Thread: 0 CrBrowserMain Dispatch queue: com.apple.main-thread
Exception Type: EXC_BAD_ACCESS (SIGABRT)
Exception Codes: KERN_INVALID_ADDRESS at 0x000000d800000324
Exception Codes: 0x0000000000000001, 0x000000d800000324
VM Region Info: 0xd800000324 is not in any region. Bytes after previous region: 446676599589 Bytes before following region: 104625403329756
REGION TYPE START - END [ VSIZE] PRT/MAX SHRMOD REGION DETAIL
commpage (reserved) 1000000000-7000000000 [384.0G] ---/--- SM=NUL …(unallocated)
---> GAP OF 0x5f9000000000 BYTES
MALLOC_NANO 600000000000-600020000000 [512.0M] rw-/rwx SM=PRV
Application Specific Information:
abort() called
Kernel Triage:
VM - (arg = 0x3) mach_vm_allocate_kernel failed within call to vm_map_enter
Thread 0 Crashed:: CrBrowserMain Dispatch queue: com.apple.main-thread
0 libsystem_kernel.dylib 0x18363a0dc __pthread_kill + 8
1 libsystem_pthread.dylib 0x183671cc0 pthread_kill + 288
2 libsystem_c.dylib 0x18357da40 abort + 180
3 Ruby 0x106f69888 die + 12
4 Ruby 0x106f69944 rb_bug_for_fatal_signal + 188
5 Ruby 0x1070f839c sigsegv + 100
6 libsystem_platform.dylib 0x1836a1a24 _sigtramp + 56
7 libQt5Gui.5.dylib 0x2b59edf84 QWindow::setTitle(QString const&) + 64
8 libQt5Gui.5.dylib 0x2b59edf84 QWindow::setTitle(QString const&) + 64
9 libQt5Widgets.5.dylib 0x2b47e31b0 QWidgetPrivate::setWindowTitle_helper(QString const&) + 104
10 libQt5Widgets.5.dylib 0x2b47ee644 QWidget::setWindowTitle(QString const&) + 248
11 libvfb2_qt.so 0x2def42098 0x2deecc000 + 483480
12 libQt5Core.5.dylib 0x2b55ca6b8 QMetaObject::activate(QObject*, int, int, void**) + 2352
13 libvfb2_qt.so 0x2df00ca60 0x2deecc000 + 1313376
14 libvfb2_qt.so 0x2def5b748 0x2deecc000 + 587592
15 libQt5Widgets.5.dylib 0x2b47f3e98 QWidget::event(QEvent*) + 988
16 libvfb2_qt.so 0x2def5dce0 0x2deecc000 + 597216
17 libQt5Widgets.5.dylib 0x2b47be038 QApplicationPrivate::notify_helper(QObject*, QEvent*) + 292
18 libQt5Widgets.5.dylib 0x2b47bf3cc QApplication::notify(QObject*, QEvent*) + 556
19 libQt5Core.5.dylib 0x2b559c11c QCoreApplication::notifyInternal2(QObject*, QEvent*) + 204
20 libQt5Widgets.5.dylib 0x2b47ec7f8 QWidgetPrivate::sendPendingMoveAndResizeEvents(boo l, bool) + 248
21 libQt5Widgets.5.dylib 0x2b47f2bb4 QWidgetPrivate::show_helper() + 52
22 libQt5Widgets.5.dylib 0x2b47f3960 QWidgetPrivate::setVisible(bool) + 808
23 libQt5Widgets.5.dylib 0x2b47f2f58 QWidgetPrivate::showChildren(bool) + 364
24 libQt5Widgets.5.dylib 0x2b47f2bd4 QWidgetPrivate::show_helper() + 84
25 libQt5Widgets.5.dylib 0x2b47f3960 QWidgetPrivate::setVisible(bool) + 808
26 libQt5Widgets.5.dylib 0x2b47f2f58 QWidgetPrivate::showChildren(bool) + 364
27 libQt5Widgets.5.dylib 0x2b47f2bd4 QWidgetPrivate::show_helper() + 84
28 libQt5Widgets.5.dylib 0x2b47f3960 QWidgetPrivate::setVisible(bool) + 808
29 libQt5Widgets.5.dylib 0x2b47f2f58 QWidgetPrivate::showChildren(bool) + 364
30 libQt5Widgets.5.dylib 0x2b47f2bd4 QWidgetPrivate::show_helper() + 84
31 libQt5Widgets.5.dylib 0x2b47f3960 QWidgetPrivate::setVisible(bool) + 808
32 libQt5Widgets.5.dylib 0x2b47f2f58 QWidgetPrivate::showChildren(bool) + 364
33 libQt5Widgets.5.dylib 0x2b47f2bd4 QWidgetPrivate::show_helper() + 84
34 libQt5Widgets.5.dylib 0x2b47f3960 QWidgetPrivate::setVisible(bool) + 808
35 libQt5Widgets.5.dylib 0x2b47f2f58 QWidgetPrivate::showChildren(bool) + 364
36 libQt5Widgets.5.dylib 0x2b47f2bd4 QWidgetPrivate::show_helper() + 84
37 libQt5Widgets.5.dylib 0x2b47f3960 QWidgetPrivate::setVisible(bool) + 808
38 libvfb2_qt.so 0x2def3e520 0x2deecc000 + 468256
39 libQt5Core.5.dylib 0x2b55c371c QObject::event(QEvent*) + 464
40 libQt5Widgets.5.dylib 0x2b47f4b30 QWidget::event(QEvent*) + 4212
41 libQt5Widgets.5.dylib 0x2b47be038 QApplicationPrivate::notify_helper(QObject*, QEvent*) + 292
42 libQt5Widgets.5.dylib 0x2b47bf3cc QApplication::notify(QObject*, QEvent*) + 556
43 libQt5Core.5.dylib 0x2b559c11c QCoreApplication::notifyInternal2(QObject*, QEvent*) + 204
44 libQt5Core.5.dylib 0x2b559d338 QCoreApplicationPrivate::sendPostedEvents(QObject* , int, QThreadData*) + 796
45 libqcocoa.dylib 0x2ae72e084 QCocoaEventDispatcherPrivate::processPostedEvents() + 312
46 libqcocoa.dylib 0x2ae72e748 QCocoaEventDispatcherPrivate::postedEventsSourceCallback(void*) + 48
47 CoreFoundation 0x18374fa4c __CFRUNLOOP_IS_CALLING_OUT_TO_A_SOURCE0_PERFORM_FU NCTION__ + 28
48 CoreFoundation 0x18374f9e0 __CFRunLoopDoSource0 + 176
49 CoreFoundation 0x18374f750 __CFRunLoopDoSources0 + 244
50 CoreFoundation 0x18374e340 __CFRunLoopRun + 828
51 CoreFoundation 0x18374d9ac CFRunLoopRunSpecific + 608
52 HIToolbox 0x18dcfc448 RunCurrentEventLoopInMode + 292
53 HIToolbox 0x18dcfc284 ReceiveNextEventCommon + 648
54 HIToolbox 0x18dcfbfdc _BlockUntilNextEventMatchingListInModeWithFilter + 76
55 AppKit 0x186f2a8a4 _DPSNextEvent + 660
56 AppKit 0x187704980 -[NSApplication(NSEventRouting) _nextEventMatchingEventMask:untilDate:inMode:deque ue:] + 716
57 AppKit 0x186f1dd50 - + 476
58 AppKit 0x186ef5014 NSApplicationMain + 880
59 SketchUp 0x104a35308 main + 140
60 dyld 0x1832f10e0 start + 2360
Thread 1:: ThreadPoolServiceThread
0 libsystem_kernel.dylib 0x18363d7c8 kevent64 + 8
1 Chromium Embedded Framework 0x11e68e22c cef_time_delta + 2800700
2 Chromium Embedded Framework 0x11e68e114 cef_time_delta + 2800420
3 Chromium Embedded Framework 0x11e635f40 cef_time_delta + 2439504
4 Chromium Embedded Framework 0x11e60b518 cef_time_delta + 2264872
5 Chromium Embedded Framework 0x11e63efa0 cef_time_delta + 2476464
6 Chromium Embedded Framework 0x11e65086c cef_time_delta + 2548348
7 Chromium Embedded Framework 0x11e66e4f8 cef_time_delta + 2670344
8 libsystem_pthread.dylib 0x183672034 _pthread_start + 136
9 libsystem_pthread.dylib 0x18366ce3c thread_start + 8
Thread 2:: ThreadPoolBackgroundWorker
0 libsystem_kernel.dylib 0x183631874 mach_msg2_trap + 8
1 libsystem_kernel.dylib 0x183643cf0 mach_msg2_internal + 80
2 libsystem_kernel.dylib 0x18363a4b0 mach_msg_overwrite + 476
