Hello, Vray cryptomattes and tycaches (or tyflow) they never worked.
The only way I find to make it work with vray is senting the render mode in to “meshes” instead of the default “instances”. Is not ideal at all, because we loose instancing in one hand not good with lots of particles, and we need to bake the velocities if we have changing topology.
With instancing on, I was expecting that if I have different tycaches objects, each with a single name, or with a different material, or placed in a different layer, they will show as different cryptomattes. But thats not the case, as you can see on the video. All tycaches show with a single crypto value, except (and thats the weird part), that if you create additional objects in your scene, the different tycaches will display different colors. The problem with changing topology is that those colors are not consistent, and they are not usable.
-Theres two different solutions that would be great:
First one, is that having different individual different tycaches, each one gets a different cryptomattes even on instance mode. (we should make sure this works as well for materials, and when a tycache is loading materials from a material library).
The second and more advance, ideal, and more flexible, is that we can have different cryptomattes even with one single tycache on instance mode. If we use “Node user property”, or an additional ID type, where vray looks for a data channel for each particle. In this way the user can store for example the BirthID as a data channel, where particles with the same BirthID data channel will share the same cryptomatte.
