Hi.
I’m using VrayCurvature map in a thin (1 mm) object and I think it “reads” the other side some how. The whole objects becomes black if I use larger radius than 1 mm in it (smaller renders ok), but I need to use something like 1 cm in it. Is there any way to ignore the other side, or how to say it better… ignore backface or something. Hope you know what I mean
Thanks in advance
Mikko.
