Hey folks,
I’m currently working on incorporating some shots into drone footage that we had shot in 4K ProRes with a D-Log profile.
What is the best way to go about this? Do I use a LUT to correct the drone footage and then comp on top, or do I try to get VRay to render to D-Log, comp them together and then use a LUT to correct both?
Or should I do away with a LUT and grade by eye/scopes instead?
Thanks in advance.
Chris
