Vray Decal Displacement?
Does the vray decal object support displacement in this release? I can’t seem to make it work at the moment.
Love the release thus far!8)
Also does it matter if the opacity mask in done thru the material opacity slot rather than the objects?
There will be displacement support in the future.
Masking through the decal itself works better for now, we’ll make it the same for the mtl opacity when we get there :slight_smile: If you insist using the mtl opacity, just switch the opacity mode to “clip” .
Awesome, thank you for the quick response!
Hello there,
Decals is a great improvement ! Though, is there any plane to make the “bend modifier” usable on it ? Would be a real game changer in my case. Otherwise I still have to use the old trick “create a plane+create a blend material” …
Have a good day.
What do you mean, deforming the gizmo?
I assume he means to be able to wrap the modifier around a tube using a bend?
We have plans to extend the set of gizmo shapes available, at least to a cylindrical one (which would work for bottles and the like).
More shapes are being considered.
Well the decals is behaving like an object. I would like to modify this “object” to bend it.
Practical example : you have a road, you want to put some straight painted lines. Decals alow that, but if you want the decals to folow the turns of the road you can’t. In this case I still have to use the trick to bend a plane used as a decals.
Is there any way to make it possible ?
Best regards.
That kind of usage is done with standard mapping.
The goal for this tool would be to easily add, say, drainage covers here or there on the road surface.
Well, it may be for manhole covers but it makes pretty quick work out of stuff that can take hours to UV properly for surface painting.
Would love the to test displacement if it every makes it to the nightlies!8)
Also I wonder if there is an option for decals to have a affect diffuse only, affect displacement only, affect normal only option.
We’re thinking about this as well, but it will require a lot of work and maybe surface as a completely different feature.
I gotta say this is probably the most (for me at least) useful feature I’ve seen added in a long long time. Adding quick capping to walls, quick and dirty paintings/pictures to walls, adding very fast snow to an entire scene, road markings etc. So easy and so fast now.
Yeh this does seem like a scene building game changer. Id like to know if there are any scene and mem ory overheads when using more than a few of these. Does for example, 20+ of these in scene have an impact on how responsive things are? Firing up RT as an example.
It should scale fairly normally with the number of shaders and textures at play, while using the decal gizmo shouldn’t have any noticeable impact on speed or memory.
Edit: Had not seen above reply.
