I realise that the depth of field for vray is calculated from the center of the camera in a spherical way, but for a particular project I require the depth of field to be flat on to the camera so basically there is no falloff towards the edges. Is this possible ? I would prefer to use vray depth of field as oppose to post depth of field as the results are nicer.
The V-Ray physical camera does flat DOF by default.
Would this change if I adjusted the FOV ? because if I look at the vray zdepth channel, the zdepth falls off towards the edges
I am guessing you would need a math formula to take the proper Z-depth position that gets converted to a value that represents a flat plane…Scripting
Sounds rather complicated…and I know nothing of maths though.
The physical camera doesn’t use the z-depth channel, so it doesn’t matter what it looks like…
for some reason i cant seem to get the same DOF effect in my physical camera as my regular camera? its not blurring as much even setting the focal distance?
