Vray Dirt Invert Normal
Has the invert normal parameter in vray dirt been removed in vray 5? if so what’s the new equivalent parameter to generate the same effect?
Cecil
Hi Cecil, use the Inner Occlusion mode to change the direction of tracing rays and invert the effect with respect to surface normals.
To read more about Inner occlusion and see some examples, you can check here: V-Ray for 3ds Max
