vray dirt on gpu
Making some test with vray-dirt on CPU it works but it seems not working on GPU ? I miss something ? Thanks for your report
Hi @eric_kubiak thank you for reaching out to us! V-Ray Dirt texture currently does not work on GPU. with V-Ray 6. The matter has been logged into our system [VC4D-1619] and will be looked into.
Hi
Try to change “Affected By” to exclude list. The dirt texture will work
Best,
Muhammed
Indeed, the current default is set to “affected by” but obviously by default there’s nothing specified in the “affected by” list because you have to do that manually therefore nothing is affected :slight_smile: Changing this setting or dropping your mesh into the affected by list should make things work :slight_smile:
Thanks for your answers, I will check this. Considering using the curvature node as well but more tedious to work with. Have a good day !
