Vray Dirt - Radius input with texture has no effect
for me the radius input in a dirt texture has no effect, no matter what I try.
Could you please cross check?
Thanks and cheers
Dominik
It’s some USD version change… previously if you have connection to the texture the parameter value was still resolved, and now the parameter value is empty (in this case radius will be texture multiplier, and since value is incorrect - mult result is also incorrect…)
Will have to workaround this somehow..
Thanks Andrei for your clarification
Do have any idea when it could be implemented in a nightly?
Yes, it could…
Hi Andrei,
thanks, works like a charm in the latest nightly!!
sorry for bothering - do you think the issue gets resolved in the near future (days), because the client produces some pressure and I would need the dirt map to work…
Just asking :wink:
Thanks Dominik
