Vray Dirt radius Map in Maya
Hi
Does anyone have a simple set up for plugging a texture file into vray dirt radius in maya?
It doesn’t work if you simply plug it into the slot, I need a method whereby i can use the map as a range of values within a global radius value.
I have found a method from a google search which uses a multiply divide node (and a luminance node) - which seemed like a sensible solution to me- but it doesn’t work either.
thanks
Hello Bertjenkins
Here is one example how to connect a texture Map to VrayDirtTex radius , and with the help of the MultipleDivide node , you can control the radius.
You can even add a second texture with second MultipleDivide node for even more control over the radius.
Scene File >>
VrayDirt.zip (8.88 KB)
Great thanks.
Why is the multiply divide node needed? Is it because the texture map colorOut only gives values of 0-1?
In future will you be able to map images straight onto the radius with a multiplier, as for lights, etc?
I just tried the same thing without the multiply divide node, but using the out alpha of a file texture node and adjusting the alpha gain to high values (eg 40, etc) it looks the same. Is this technically the same thing?
Yes, it’s the same thing.
great thanks
Nice svetlozar_draganov, thank you for posting this!
