VRay Dirt Support - 3dsmax
Will support fo vray dirt be coming anytime soon? I use this map on practiclly everything - it’s so important. Otherwise, can anyone suggest a workaround?
Apologies if this has already been raised.
Hi Montage,
Support for VRayDirt won’t be coming anytime soon but it is in our TO DO list. Cannot give ETA unfortunately.
Alexander
Yes it is much important
Can you tell us how you use it ?
What do you connect it to most often ?
Do you texture the dirt radius ?
Do you use it as the blend amount for a V-Ray blend material ?
Generally, the V-Ray Dirt texture might reduce performance by a lot, since it has to fire additional rays into the scene.
Greetings,
Vladimir Nedev
I also think Vray dirt is very useful in architectural visualisation. I use it a lot for create a more natural look on objects’ corners. And I often use the mapping for the dirt radius. I really hope this can be implemented soon in Vantage, along with Vray distance tex, that’s another incredibly useful feature.
Cheers
Do we have an update on when full support of Vray dirt and Vray blend map is coming ? Both are very important in archviz I feel.
Hi all,
Support for VRay Dirt and VRay blend is not as high a priority as other features(like render elements, scene variations, animated textures, etc.) so it will not probably be available soon. We will let you know when there is some development.
Alexander
