can’t find a way to make displacement work with instances.
- using a displacement map on the MATERIAL: no results with tyflow, forest pack, chaos scatter
- using a displacement modifier on the instance (e.g. a sphere with vraydisplacement mod scattered over a plane) set to “use material” - same as above.
- using a displacement modifier on the instance with the bitmap in it - works only with chaos scatter with vray CPU (not gpu).
You could use the VRayInstancer to distribute instances instead. Make sure you enable the Particle Interface in tyFlow (Interfaces>Enable particle interface). FP surely has a similar option.
but this used to work with FP and TyFlow as well in past releases
Can you recall the specific versions of Forest Pack and V-Ray that worked? I tried to install older versions but they render no different that the latest.
