Vray Displacement on Carpet with breaks
Still have not figured out why I am getting sudden breaks in displacement on some objects just like the one on the enclosed image
Both the floor and the grass are simple 2D polylines extruded up and mapped. I am using 2D VrayDisplacement. Default MAX displacement is turned OFF. I have tried Tight Bounds option both checked and unchecked - no difference. It is not a smoothing issue either, I have applied Smooth modifier to remove all Smoothing groups before Displacement. Adaptive Subdivision -1/+1 Threshold 0.1. Any ideas ?
This is with Fixed Rate: 1.
Clearly visible.
if you’re not already, try using a standard material for the color, and select Faceted.. that has a tendency to clear up a lot of my various Displacement oddities.
:idea: :idea: :idea: Cool Tip ! :shock: :smile:
It really did the thing. Thanks alot Dbuchhofer. :wink:
looks like a normal problem.?!
S.wolf
Using box mapping also seems to fix that particular error, even if mapping a plane.
richard is right..
had the same plane yesterday..
regards
S.Wolf
