Vray Distribute rendering : Can't connect, rejected request
Hi Chaos!
I’ve installed Max 2021 and as you help me to install Vray 3.7 with that, it work like a charm.
But for a reason i don’t know since the last windows update it seem the connexion is lost between my WS and my nodes.
I’ve try to cut the firewall rules, and cut EVERYTHING between WS and my nodes but there seems to be a problem.
I’ve try to connect to the status panel http://localhost:30304/#/bundle/ and i can see my dongle, my WS and my 14 nodes on my dongle.
But i’ve all my nodes open… and anyone is count on the status panel…
If you’ve got an idea…
I’m aware…
Thx!
Mmm @vlado or someone? Please :cry:
Try reinstalling the license server on your workstation and slave machines and see if that makes any difference. Also, check if ‘VRLService’ is running (Task Manager>Services).
Ok, so i’ve uninstall every licenses which’s running everywhere, re-install Lic 5.5 and lauch Vray license service everywhere also…
So…
I’ve got that :
For info i’ve stopped WinDows Firewall activity, in local as in public for the test, and it done the same result.
Please … I need a little solution…
Thanks in advance!
I’ve try to transfer my license online to see if there is something better…
But… NO
I hope you can help…
Ok it’s so stupid…
The solution is that my Distribute render’s option is set with the wrong mask parameters…
30304 and not the right one : 20204…
so for the future…
Don’t write the mask number … it will do the trick automatically… and with the good things…
