Just was thinking… Well more than just thinking. I need to make soon 10 PC server build to maximize render times on 1 Big 10k + images. I was just wondering, how much data actually Vray send/recieve? Do I need some special router that can handle so big bandtwich or will standard 100£ do the job just fine?
Also does DR is limited by CPU or System in total ? For example I can have 10x Quad, or 10x 2x Xeon 6 core? Or will I run in problems with xeons that I can only use 5 of them…
Also is there any way to break that 10 pcs barier? To up to 20 maybe or so…
At the start of the rendering, V-Ray needs to transfer the .max file to all the render slaves. During the rendering process itself, V-Ray only needs to transfer bucket data, which on the whole is not that much. However if there are resources like textures, proxies X-Ref scenes that must be loaded from a shared network resource, this will increase the traffic.
The DR licenses are per machine, regardless of the CPUs or number of cores. Each workstation V-Ray license adds 10 DR licenses (so if you have 2 V-Ray licenses, you can use 20 machines and so on).
ooo thats great news. I always thought that its limited because of something… dunno what but good to know it. Thanx for ur time Vlado ! Also quick question. When I send work to render using DR… can I then use my laptop and work with vray ? Or should I send it to Backburner and then use my laptop to work with vray ? I got 1 pc currently so I cant test it out on my own unfortunately…
V-Ray has a UI and a render license; it is possible to render on one machine and use the interface on another, but you can’t render or use the UI on two machines at the same time, if you have just one license.
