Vray does not update if i move USD proxy shape.
If i use Viewport rendering Vray does not update if i move the USD proxy shape.
Arnold does. Is there a way to get this working?
Is there no way to get this working?
How are you loading the USD file?
Doesnt matter if i load it via Maya Create USD Stage or Bifrost.
This happens all the time which is annoying. You have to re-launch vray each time that you update anything on the USD side of things. Hopefully, this can be fixed soonish.
Hey there,
Moving the USD without saving the changes to the USD stage is considered what we call in-memory changes.
We don’t have a way of detecting those in IPR, but it’s something that we’re looking into.
For the moment, any in-memory changes cannot be detected while IPR is running.
So its secret sauce what Arnold is doing?
I’m not sure. At one point we did try to make it work, but we couldn’t find a reliable method and we had no luck.
We are coordinating this with Autodesk so hopefully we’ll figure it out.
Would be great to get this working!
