Vray Dome light & Vray Sky not refreshing during IPR on Vray NEXT
Hi!.
I don´t know if something change during Vray NEXT 1.1 but since this update if i use a VraySky inside my Dome like i always do I´m not getting refresh Sky when i move the sun. In order to refresh the sky i need to perform changes on the dome (like disabling and enabling it). I try it on different computers and i assume it´s something related to 1.1 update.
¿Can someone confirm if this is working as intended or not?
Best Adán.
Manually select the sun from the VRaySky’s parameters and please try again.
Hi!.
Thanks Slizer. It´s the temporal “solution” i´m using right now but it´s a problem, because every time i change something from the sky (Ozone, turb, etc) i need to change it in both, Sky and sun, this forces me to do double the clicks during IPR work. This feature was working perfectly before :frowning:
Hi again. @matanov
Just want to know if this is working as intended or if it is a bug and will be fixed in the future. Thanks
+1
Yeah fixing that would be cool
