VRay DR and Forest Pack
I had installed Vray 3.60.01 and Forest Pack Pro 534b.
I have two workstations (Win7) and in DR they are ok.
On my render nodes (Win XP) the Forest objects don?t show up. I think it was a problem of paths and then i modify the 3dsmax.ini on render nodes. A no go? after some test, I verify that VRay DR modifies the render nodes 3dsmax.ini and the paths of Forest pack are removed?
I need help? In previous versions, all work
Thanks in advance
Hi, Nicolau,
The right Fp version for 3.60.01 is Forest Pack Pro v5.4.0. Normally V-Ray does not modify 3ds Max’s .ini files directly, excluding for the plugins.ini only during installation, can you show me the proper and the modified files I would like to compare the changes? Because this file is located “C:\Users\sasho\AppData\Local\Autodesk\3dsMax\2018 - 64bit\ENU\3dsMax.ini” I suspect that 3ds Max updates it anyway.
Alexander
Maybe set the file to read only?
