Vray DR and texture problem, help pls
im rendering a scene with DR, slaves buckets render without textures BUT i check maps and they all pass thru network path. ANyone has solution to this?
Ryan
Well those machines are simply not seeing those maps.
What paths are you using mapped drivers or UNC
Example:
g:/textures/map.jpg
//server/textures/map.jpg
Try copying the maps local on each machine.. that will work.
im using //server/textures/map.jpg.
i tried rendering using the slave machine not DR and it renders all maps just fine. but not when using DR:(
i had fixed the problem now, i just transfered my slave to another network port.
Ah cool.. easy fix :slight_smile:
