Just updated my hardware and software--i7 workstation with 12 GB DDR3 Ram on Windows 7 prof 64 bit. (all max 2009 64bit +Vray 1.5 SP3a)
Slave Quad Q6600 + 4 GB Ram/ windows xp 64bit
It seems that DR does not work…I connected the network drive (Z /all max stuff) as usually from the slave---all windows firewalls off…i have network access on folders between the two computers.
Vray installtion quite normal…when it comes to DR: Spawner starts normal.
I get no failure notices in the Vray Log (Box)---just scene transfered to XXX.XXX.X.X (IP) and starting in brown color…then i can see in the task manager that CPU usage etc is raising to 25% for some seconds---the 0% and nothing…
no failure notice like render host failed etc…
just the workstation renders with 8 buckets---no slave
ok there comes now also the failure notice that the render host is unkown is not responding…
with win xp 32bit and winxp64bit (slave) everything worked fine- just for info
Any ideas?
Thank you!-never change a running system---i changed…lol
Well. Try to update your drivers. We have integrated marvell yukon controller, and somehow eyeon fusion slaves just got stuck at some point. We updated win 7 drivers and everything went smooth, but I never had this for vray.
BTW - we’re using win7 RC (me using server version, the workstation with fusion using plain win7). Still not sure if I’m interested in server stuff or maybe win7 enterprise…
the whole network (2 slaves/ 1 workstation/ 1 laptop) is now set up by static IP, by Hand / @router DHCP disabled…everything works fine-internet on every machine, but NO DR and Backburner with Vray…
I m getting from the nodes (per browser…) no contact to the workstation with dongle(licence)…???
