Vray DR Problem
I hope somebody can help me here…
My configuration: 2 computers for Rendering
workstation: at the moment win xp prof 32 bit+3dsmax 2009 service pack1+Vray 1.5SP2
slave: now windows xp prof. 64 bit with 3dsmax 2009 service pack 1 32+64 bit with both vray versions( 32,64bit) for DR
When i was on both with win xp prof everything worked fine---but now i had to reinstall the slave and i thought why not win xp 64bit--because the slave has 4 GB RAM.
pinging between the computers is no problem…everything quite normal.
Vray Spawner also works---there are no crashes.
But when rendering in DR mode the slave can t render.
Vray log says: server xxx scene loaded, starting render
          ??? server xxx, render completed ???
the in green: wwarning: render host xxx is not responding----
Has anybody some advices?
Is the windows firewall enabled?
re
problem solved.
re
windows firewall was off…but it s solved now thank you
Excellent! what was the problem?
re
with windos xp prof 32 bit i just installed the DR/networkrendering installation without telling him the IP where the vray licence is running..everything worked fine…now i just had to tell him the IP of the workstation where the licence is running…that was all-
:smile:
DOH ..
trying to problem solve human error is the hardest problem to solve.. :smile:
We often have this problem too. Have noticed that we only have the problem with large files (200+ Mb). Small files is usually no problem. Sometime it helps to “wake-up” the renderfarm by sending a small file to rendering before sending the large file to.
/Chris
DR Large Max Files
Has anyone else experienced problems Distribute Rendering large Max files, say +100mb? I usually don’t have a problem with small files but everytime I have a large Max file none of the Render Slaves pick the job up. Any suggestions/tips/tricks??
Thanks in advance,
Yes, I have the same issue. Files that are typically over 100MB will not DR. No solution found on this end, perhaps XREF’s.
