Vray + Dreamscape?
Please:I need from Gonzalo or another vray master to explain what is the advantage of using Vray + Dreamscape together?
Instead using the usual methods, for architecture,if you don’t need snow,mountains, oceans,etc.
Appreciate it!
Hi Daniel,
Advantages from point of view is:
Animated water
Anymated Sky 2d/3D
Sun Effect
Daylight symulation
Model terrain tools based on brush tools
Disadvanges we cant use Vray as current renderer in Material Editor, since I only use Vray materials I cant see them
Gonçalo
here is a good question. does the dreamscape sky give a better lighting than if you used a flat color in the override environment slot?
is it better than HDRI sky ?
lets say DOSCH super hires HDRI skyes or other ?
:shock:
No isnt better at all, its good for reflections thought…
Gonçalo
unfortunately dreamscape environments are not hdr.
Here is one - DreamScape Sky with VRay Antialiasing by default do not flicker in the animation. :slight_smile: Wit scanline you have to turn AA in DS what make it very very slow
