Vray Emissive Material Problem
I can’t create an emissive material. I followed the vray for rhino manual but i can’t obtain the same result. Are there any special settings to set in vray render options like illumination or similar? I want to create a red led light and a screen illumination, something similar to ipod. Please help me! ??? ??? ??? ??? ???
Re: Vray Emissive Material Problem
Maybe you use the phys cam and than you must set the intensity of the emitter material very high - try 1000 or more.
I set the intensito to 1 or maybe 2… i will try with 1000 ::slight_smile:
Yes it is a bit of a hassle. We’re planning on supporting physical light units as soon as possible. This should make it a bit easier to gauge proper intensities for a given exposure.
This is the result T obtain with 1000 of intensity… I’m quite happy… for a simple test
How can i color the light? Some texture or any special setting in the materials?
Assign a texture to the emitter material. For making materials read the tutorial here:
