Not sure if i’m not setting this up correctly or if there is an issue but when i create an example object, download an enmesh pattern from cosmos, it automatically gets applied but doesn’t show up in the render as you can see below. What exactly am i doing wrong? Is it a setting that’s not correct. I’m using Sketchup 2025 and Vray 7.2. Rendering with CPU.
Hello @levente_redecky ,
Thank you for your post!
Please take into account that Enmesh is generated based on the UV mapping of the surface that Enmesh is applied to.
To preview UV mapping and adjust the size go to Viewport Display settings of the material and change mode to Custom.
Example:
Try adjusting UV of the texture and let me know if it works for you.
(Convert C07_Caramel_Shine SketchUp’s material to V-Ray material to adjust mapping as shown)
Hi Natalia,
Thank you for the help! Knew i was missing something haha. All works now and makes sense
Glad to hear that it works now! I appreciate the confirmation
