yo,
anyone experienced this?
happens when trying to save from VFb
how do i get rid of it…dont wanna redo the scene from scratch
thanks a lot for help
best regards
yo,
best regards
When do you get this message? At the start of the rendering or at the end?
the end…after i click on the save icon in VFB and specify the output path…strange, i can sometimes eliminate this by restarting max, but it does not work with this scene ![]()
this happened to me too, and was related to 3dsmax running out of memory after a particularly heavy render.
indeed its a memory issue. Try render directly to .vrimg
yep
but i have 8gigs of ram guys!!! ![]()
will try to restart
it happens when two instances of max r open
Stupid question but you didn’t mention it… you are running x64 right?
yeah sorry guys, i should have done that in the first place ![]()
yep, running 64bits vistas as well..
closing the other max allows me to save the image , but still its a kinf of annoying…ive had still 3 gigs of RAM free
this stuff now happens on most of my scenes, even if i have only one max open…grrrrrrr…
my system resources show i have only 1.86Gb in usage…so its defo not a memory issue!
Vlado could you please help? i simply cannot finish a project with this bug happening
thanks a lot
best regards
what size/s are you rendering to?
You say you are running 64bits Vista, but are you running 64bit Max?
yep…all is 64bit, vista, max and vray
am running max9 64bit SP2
vray 1.50 SP2
vista ultimate 64bit
q6600@ 3.15GHz
8GB RAM
this happens even if the only program run is max and vray…
drives me up to the wall really…having to render to vrimg
nothing helps, restarting, reopening etc…thinking about reinstall but am really in a tight deadline here
on the other hand
it forced me to start using vrimg:))))
