Whenever I try to render my scene I get this error dialog. The scene is rather large. I have 3 gigs of ram on a dual xeon. The scene seems to render fine when I turn some geometry off. But when I turn everything on it keeps giving me this error. Unfortuantely the client wants to see everything at the same time.
Has anyone experienced this, and if so do you have any suggetions or solutions?
There is no displacement anywhere in the scene. It seems like it’s an issue with the amount of geometry. There’s a lot. I just tried the 3GB switch and now my video card is not being acknowledged.
I’m just trying to render out a still for test. Eventually I’ll render an anim. But I just want to render a damn image!
Oh, here’s a new error message! I’m so excited I can hardly stand it!
several issues…looks like you are eather:
1 - running out of memory (if you have 3gb ram you need 3 gb switch to be active to use all 3 gb)
2- you have booleaned meshes or non standart meshes which vray doesnt recognize
3- the shaders you have are not recognized by vray.
But i think its eather memory or bad geometry, vray will always give exeption if there is booleaned “bad” mesh
Well i dont know what you have in the scene and how you made it, i’d try to narrow down to what geometry exectly causes to give exeption then select the vertexes in subobject and weld them with 0.001 radius this way all vertex data that floats in 0.0 space is illiminated…that can help. Also if you have holes in you mesh that can cause same thing.
As to 3gb switch…if you have 3 gb of ram without 3g switch then you only have 1 gb of ram and 700 mb of swap for one of every program that you are currently running. That the way windows works, so when you send the render whats you task manager for memory overload.
When we switched to 3gb i couldnt restart to make my video card work eather i think if you turn off you computer then turn it back on it will work…it did for us.
You said that most of the stuff renders with out other objects which are hidden but when you unhide them it gives the exeption, try reverse, hide everthing else expet those objects and render if there is no problem then its defenently memory issue.
I did boolean a couple of objects in my scene, but they’ve been converted to editable meshs. …
As far as the 3GB swith goes, i’ve turned computer off then back on, I’ve restarted it, defragged it, updated the video drivers (before and after the 3GB switch). It still won’t acknowledge my video card.
ive had this problem when exporting a site mesh from ArchiCAD before…had to fix it in the modeller and re-export because i didnt know how to fiz it in viz.
another thing that sort of worked for me was to select the mesh, optimise it, then meshsmooth, then convert to poly mesh..something like that
i suggest emailing vlado or tisho. those guys are very helpfull
we can only really guess at the problem…
another guess is to change the default geometry from static to dynamic and increase the memory limit. I really dont know what this does, but in the past ive changed this and it solved my crash problem (i think)
You can easily check if it is a memory issue - just open task manager and check the amount of ram used for the 3dsmax.exe process. If it increases over 1.4 GB while rendering / preparing the scene you’ll get the exeption. Just hit render and watch ;).
If it is a memory issue, some points to start from / optimize:
- collapse every geometry possible down to editable meshes
- check your scene for oversized bitmaps (4k mappings on distant objects etc) and downscale everything - or as a test just apply a plain white material to everything and watch the ram again, or collect your bitmaps to one single folder and have a look at them
- check your lights and look for huge shadow map sizes (try to convert them to vray shadows although it will most likely increase rendertimes it decreases ram on render preparation)
- open scene summary and check for huge polycounts on individual objects - maybe you’ll have some polygon monsters somewhere in the back of your scene
- change the raycaster parameters, especially upping the face/level quotient may help
Well I’ve managed to merge everything into a new file and it seems to be working (at least for now). Thanks to Paulison for the reminder of this good ol trick.
i had this same problem, i just replaced the turbosmooth modifier with a meshsmooth on the object that crashed. and the problem was fixed, i’ve had the same thing when i’m using meshmooth for some objects too, then i just replace it with a new one at it works. i see that u dont got the turbosmooth since u are using max 6, but try replacing the meshmooth modifier with a new one if u are using meshmooth on the objects at all.
For me, the problem is present when i put an 3dsmax SKYLIGTH in the scene after to process the irrandiance map with just the enviroment illumination, and it happens in some rendered frames not for all (in an interior animation).
Personally, never happened with other kind of lights, but skylight helps soooo much in the interior scenes without sacrifice rendering time and gives very good results… it´s a shame that vray don´t like skylights.
The same happens with the “overbright surface…” message…
My models are normaly imported from AutoCAD (for architecture) and never, until now when i discovered the benefits of skylight interior lightning, this kind of warnings and errors were showed…normally the import settings to max are set to “weld options” 0.01
How could i fix this (my max memory using never goes after 340 of my 1.5gb ram, that´s why i think it is not a memory issue).
