Hi everyone, I´m rendering an ocean environment, after a short while the buckets rendered are black and this error pops up. The issue seems to be related to a large volume box I´ve added for the atmospheric fog. If I hide it the rendering finished without errors. You can see the setup in the second image. The error persists even if I convert to vdb instead of Houdini native volume.
Any ideas on how this can be fixed? Thanks
Using Houdini 18.5.499 and the latest official release Vray 51020.
@Ambrozie Hi, just because we have seen a very similar error message (and this might have a totally different cause on your side) - but for us it turned out to be a memory (or actually running out of memory) issue while trying to render a single images of a production scene which usually renders in HD getting rendered at very high resolution for print. So it might be worth looking at your memory while rending the image.
