Vray file converter
So is Chaos going to create a file conversion tool that is as good as Corona’s converter. Vray’s converter is hella anemic. With the Corona one I can take a Vray file and covert with confidence. I can convert the whole file or I can convert only the selected items. A lot more tools. This would be great since I am a Corona user and have to convert my Corona files in order to use Vantage.
The V-Ray converter does the same thing, as far as your mentioned options.
Guess I will jump in and ask if they will ever add converting physical cameras to vray cameras? I have to use Lele’s conversion script. Or am I missing something?
It does…maybe I’m doing it incorrectly. Can you send a link showing the interface and how to access? I just right click and select vray file converter.
