Vray Fog Voumes / Geometry Slicing
When i use a Vray Fog volume on a gizmo, in my render i am getting wierd slicing in the geometry where the gizmo intersects with the meshes.. Ive made a quick scene to demonstrate the issue. Any advice would be helpful?
Im using max 2025 + Vray latest version.
Vray_FogBug.zip (7.2 MB)
This issue seems to be related to ray precision. It typically occurs when the camera is positioned far away (35 km) from the subject while rendering at a high resolution.
Moving the camera closer and adjusting the Field of View (FOV) to match resolves the problem. At this distance, the camera adjustment produces almost no visual difference in the final image.
We have moved the camera halfway and adjusted the FOV accordingly.
You can see the result here:
Hope this helps.
ah great ok.. the reason we moved the camera so far away is we wanted to get the viewport (camera) as close to othographic as we could since Vray cameras dont support true orthographic views like Max cameras? (we had to force orthographic in the render settings) ill try your example though
Hi Joseph,
We can now see that you’re using an orthographic camera, which is actually better.
The same approach applies.
Just make sure the camera is not positioned too far away to avoid ray precision issues.
