Vray for ArchiCAD
How do you do it?
export to 3ds, import into 3DSMax, delete extra faces, weld vertices, apply materials, light and adjust vray settings and then hit render. :smile:
marc lorenzo has a free ArchiCAD import plugin
maybe u should try that
regards,
mark
How do I get the ArchiCAD plug-in?
sound good to me. I have seen some great results of ArchiCAD with Vray. The problem is that I dont have 3DSMAx.
You have VIZ? same method would apply, but I am guessing you’d like to render right out of Archicad? which is not possible.
I do have VIZ r4. (don’t know how to use it)
so save to .3ds, open in VIZ,(can I get a Vray add-on for VIZ ?,
I found this great link.
