Vray for houdini install issues
Error running Python dynamic menu strip script:
Traceback (most recent call last):
File “<stdin>”, line 6, in expression
File “C:\Program Files/Chaos Group/V-Ray/Houdini 19.0.455/vfh_home/scripts/python\vfh\vfh_rop.py”, line 198, in vray_rops_as_xml_menu_items
VRAY_ROPS = TYPE_VRAY_ROP.instances()
AttributeError: ‘NoneType’ object has no attribute ‘instances’
AttributeError: ‘NoneType’ object has no attribute 'instances’​
Dear @alexander_mann ​, hello.
Please define the build that you are trying to install - is it from our Download section, latest stable build or?
You could add here a screenshot showing the name of the downloaded file.
Important is also the Houdini version.
Is there a discrepancy between Houdini version and the Houdini version displayed in the build name (here is 19.0.455)?
Waiting for your answer.
​​​​​​​TS
Hi, i am trying to install it on houdini 19.5, whereas the vray software is 19.0.455.
Yes the product is from your downloads section.
I followed the instructions found here: Installation
I put the install packages into houdini 19.5 packages folder
Okay, this is the reason.
Don’t worry, just find the correct V-Ray build for the exact Houdini version here.
Please confirm that you are successfully accessing this page.
Hi, thanks so much, i can see the version for the correct Houdini now.
