Vray for Nuke 11. Installation Problem
I have a problem installing Vray for Nuke 11.
I want to switch from Nuke 10.5 to Nuke 11. But I cant see any Vray things in Nuke 11 after installation.
In Nuke 10.5 all works fine.
Just updated both Nuke Versions to Vray 37001. Same Problem
The plugin folder from 10.5 and 11 looks different is that correct? (see the attached image)
Perhaps some body have a hint for me.
Carsten
Hey,
Can you get us the install log so we can find out what is going on? You can find it at C:\Program Files\Chaos Group\V-Ray\Nuke 11.0\uninstall\install.log
Also note that there are separate installers for Nuke 11.0 and Nuke 11.1 (these are not the same and each will work correctly only with the appropriate version).
From the screenshots looks like your install location is not correct.
Can you try reinstalling again and follow the steps here - V-Ray for Nuke
Ok, sorry.
I really used the wrong installer. :sweat_smile: I always took the “vray_adv_37001_nuke11.0_x64” instead of “vray_adv_37001_nuke11.1_x64”
But thank you for opening my eyes.
Best Regards
Carsten
