Hi everyone
i have a problem with bitmap which i applied on a plane. Older version of the VRF isn’t a problem but the same file i run sr8, shut down rhino.
does anyone have an idea?
Hi everyone
Re: Vray for rhino SR8 bitmap problem
Hello Ocorhan,
if you could fill us in with more details (maybe by providing a screenshot or a file), we’d get to the bottom of your issue.
One suggestion for now: if the filename of the bitmap contains exotic letters, then the path might be corrupted and illegible. Updating Rhino can be a bit of a mess concerning downward compatibility.
So, either you re-define your material or rebuild the scene and see if it still happens.
Cheers,
Matt
1. Welcome to the ASGVIS forum (it looks is your First Post)
2. is VFR and not VRF
3. Be more specific when reporting tecnical issues (graphic card drivers, cpu…etc)
4. As Matthias Said check if the filename for any exotic chracters, keep file name simple and in a accesible folder.
5. File format, its not mandatory but PNG or JPEG are more friendly (in my case) BMP tends to be larger size and consumes more resources.
