oh but there is! Add an extratex render element, and apply the texdirt shader to that (can’t screencap right now). I believe my default radius is somewhere between 20-40. This will give you AO that is not burnt into the image, so you can level adjust in post as needed
Small wish: could be nice to get a flag option to temporary disable render elements. So, f.ex. the AO output could temporary disabled without the delete the AO setup.
I’d be into that - sometimes I just need a quick preview or something, and the only one you can switch off is denoiser. Would be helpful once your so far into the project that you don’t want to unload/reload settings, but at the same time you just need to spot check something real quick.
