Vray & Forest hard crash
Hi there !
I’ve got recent crash since i’ve upgrade recently forest & vray at the same time.
Looks like we’ve got some troubles with materials.
vray : 3.10.02
forest pro : 4.3.4
max2015 sp3 / ext2
Don’t know exactly where the crash come from, because all softs and plugs have been updated during December (max, vray, forest and more)
I join a vrayLog.
Off course, scene has been created before update, and was fine.
If anybody has an idea, i’ll take it, i’m still searching.
thanks !
-p-
vraylog.zip (24 KB)
Does it crash on every scene or just on particular one?
What happens if you create a new scene with a few Forest objects and render it with Vray?
Would it be possible to send the scene for investigation?
New scene or new forest seems to work pretty well. It just append on random old forest.
We can manually fix by reloading object into forest, but it’s pretty uncomfortable.
Are you able to render those old-crashing scenes with another render engine?
Hi, I can confirm this. Seems to be a Forest problem, because reverting to v4.2.5 solved it for me.
yea thanks for confirming.
I’m going to post on Itoo forums
Thanks for the clarification.
It would be better to contact Itoo developers directly.
I have a similar problem which appeared only after installing 3.10.02. It crashes both with Forest 4.2.5 and 4.3.4 with Max 2014.
It used to work great under 3.00.08. :frowning:
Itoo confirmed that’s related to Xref materials & Forest 4.3.4. They are on it.
Stay tuned !
Bug fixed in Forest Pack 4.3.5.
Bug Fixed confirmed.
Thanks to iToo for support !
