Is there a way to have the frame buffer load in an image sequence as a background? Currently if I want to use a sequence I have to use Mayas image plane.
You can also override the render background from the “Environment” section of the render settings. It will work the same as an image plane though.
We have other requests for loading image sequences in the VFB but I don’t know when we will get to it.
