I have a problem with rendering my vray camera view to max RFW. My view renders correctly in the VFB then when i switch to the RFW the view gets all distorted. At 640x480 it is less obvious but ehn i rnder it at 1600x1200 it is totaly out of wack. I like the VFB a lot better but i don’t think ther is a way to batch render other than to the max RFW.
no nothing…i had my camera zoom at .777at first.
So i put it back to 1 but still the same.
What is also weird is that at 640x480 it looks almost the same in both render windows but by increasing the size it get’s more and more distorted like you see at 1600x1200
Ok i created a new camera
Rendered to VFB at 1600x1200 then switch to RFW at 1600x1200 everthing fine then swithc to 640X480 for the RFW…everything wack again
The switch back to VFB changed the size to 640x480 redered everthing ok…swithc back to RFW at 640x480 everything ok too…
so it seems max keeps the output image size from VFB somehow in memory and when i change the size in RFW to soething different than what i had in VFB it renders teh image either zoomed in or zoomed out (distorted)
