Vray Frame Buffer gets lost in background
Hi i have the issue that after a few times with interactive rendering, the frame buffer stays in the background and i have to restart rhino/vray to get it back. im using rhino 7 + vray 5. Thanks in advance!
Hi felix_landwehr ,
The behavior you have described is very rare but it does happen.
If you find a reliable way to reproduce it please let us know - this will help us a great deal.
Konstantin
I have seen it too, can’t reproduce it but have a workaround. The frame buffer tab is visible at the task bar and if I click per Shift+RMB than a menu let me choose to maximize the window. So, it comes back to the foreground again, now it is needed to press the “make window smaller” button at the right upper corner and the frame buffer is stable back for now.
